NetApp Knowledge Base
CHASSIS OVER TEMPERATURE SHUTDOWN but environmental conditions are within range
1,257
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • AFF-A800,AFF-A400
  • ONTAP 9
  • Temperature Alert
Issue
"(CHASSIS OVER TEMPERATURE SHUTDOWN) EMERGENCY" alerts are reported on both nodes:
HA Group Notification (CHASSIS OVER TEMPERATURE SHUTDOWN) EMERGENCY
  • The below messages are seen from the SP-latest-system-event-logs
Record 987: Wed Aug 23 23:27:29.020000 2023 [IPMI.notice]: 0749 | 02 | EVT: 01573636 | PSU2_Inlet_Temp | Assertion Event, "Upper Non-critical going high" | Reading: 54.000 | Threshold: 54.000
Record 988: Wed Aug 23 23:27:33.040000 2023 [IPMI.notice]: 074a | 02 | EVT: 81573536 | PSU2_Inlet_Temp | Deassertion Event, "Upper Non-critical going high" | Reading: 53.000 | Threshold: 54.000
Record 989: Wed Aug 23 23:27:41.080000 2023 [IPMI.notice]: 074b | 02 | EVT: 01573636 | PSU2_Inlet_Temp | Assertion Event, "Upper Non-critical going high" | Reading: 54.000 | Threshold: 54.000
Record 990: Wed Aug 23 23:27:43.090000 2023 [IPMI.notice]: 074c | 02 | EVT: 81573536 | PSU2_Inlet_Temp | Deassertion Event, "Upper Non-critical going high" | Reading: 53.000 | Threshold: 54.000
Record 991: Wed Aug 23 23:27:51.130000 2023 [IPMI.notice]: 074d | 02 | EVT: 01573636 | PSU2_Inlet_Temp | Assertion Event, "Upper Non-critical going high" | Reading: 54.000 | Threshold: 54.000
Record 992: Wed Aug 23 23:27:53.140000 2023 [IPMI.notice]: 074e | 02 | EVT: 81573536 | PSU2_Inlet_Temp | Deassertion Event, "Upper Non-critical going high" | Reading: 53.000 | Threshold: 54.000
Record 993: Wed Aug 23 23:27:55.150000 2023 [IPMI.notice]: 074f | 02 | EVT: 01573636 | PSU2_Inlet_Temp | Assertion Event, "Upper Non-critical going high" | Reading: 54.000 | Threshold: 54.000
Record 994: Wed Aug 23 23:29:15.970000 2023 [IPMI.notice]: 0750 | 02 | EVT: 01572a2a | LED_Board_Temp2 | Assertion Event, "Upper Non-critical going high" | Reading: 42.000 | Threshold: 42.000
Record 995: Wed Aug 23 23:29:24.000000 2023 [IPMI.notice]: 0751 | 02 | EVT: 01572a2a | LED_Board_Temp1 | Assertion Event, "Upper Non-critical going high" | Reading: 42.000 | Threshold: 42.000
  • We can see the below output from the SP-LATEST-IPMI section in Autosupports.
Ambient Temp Shutdown ENGAGED
Chassis is Over Temp YES
PSU2 Inlet Temp warnhigh 54
LED Board Temp1 warnhigh 42
LED Board Temp2 warnhigh 42
New to NetApp?
