vStorage APIs - Array Integration KBs
Other Resources
- Is it necessary to modify export policies or remount datastores after installing the VAAI?Thu, 05 Mar 2026
- Does the NetApp NFS Plug-in for VMware VAAI work in iSCSI environments?Mon, 02 Feb 2026
- "Consolidation is required" when deleting snapshot on NFS/VAAIThu, 27 Nov 2025
- Is it possible to configure audit logs for OTV itself?Fri, 10 Oct 2025
- vSphere client shows lower than expected used capacity for Thick-Provisioned VMDK on NetApp NFS datastoreFri, 10 Oct 2025
- Unable to upgrade VMware ESXI from 7 x to 8 x due to Missing GUNZIP Checksum VIBSThu, 18 Sep 2025
- FlexGroup data not reclaimed after VM deletion/migration using VAAI copy offloadFri, 11 Jul 2025
- NetApp NFS Plug-in for VMware VAAI: 'Thick Provisioning' Option is Unavailable when Provisioning VMsWed, 25 Jun 2025
- Which protocol is recommended for detecting vDS and vSS virtual switches in a vSphere environment: CDP or LLDPWed, 25 Jun 2025
- VAAI Plugin fails to Install via vCenter Lifecycle ManagerFri, 13 Jun 2025
- Copy-offload VAAI slow and fallback to host based copyFri, 31 Jan 2025
- 'Thin provisioned' is not available for VM creationWed, 29 Jan 2025
- Can mount a new NFS datastore from a SnapMirror destination volume while maintaining the original datastoreWed, 29 Jan 2025
- NetApp NFS Plugin for VMware VAAI: NFS datastores show 'Unsupported' Hardware Acceleration status in vCenterMon, 07 Oct 2024
- NetApp NFS Plugin for VMware VAAI: Unable to convert thick lazy zeroed disks to thick eager zeroed when using VM templateThu, 26 Sep 2024
- Error while upgrading VAAI pluginWed, 04 Sep 2024
- How to add the NetApp NFS Plug-in VAAI to Vmware Lifecycle Manager imagesMon, 01 Jul 2024
- How to check the NetApp NFS Plug-in for VMware VAAI is being used?Mon, 01 Jul 2024
- VAAI: FlexVol clone operation fails when offloading from volume to volumeWed, 01 May 2024
- VAAI: NSX VMware VIB blocks NetApp VAAI plugin deployment on ESXi hostsFri, 08 Mar 2024
- NetApp NFS Plugin for VMware VAAI: Configure the correct NFS export policies for VAAI copy offloadMon, 20 Apr 2026
- VAAI clone operation on the same datastore is not fast enoughWed, 15 Apr 2026
- How to troubleshoot VAAI cloning issues in ONTAP NFS configurationsWed, 08 Apr 2026
- VAAI: What are the copy offload engines that ONTAP uses?Fri, 03 Apr 2026
- How to Configure ONTAP FlexGroups to allow VAAI copy offloadTue, 31 Mar 2026
- Copy-offload VAAI slow and fallback to host based copyMon, 09 Mar 2026
- NetApp NFS Plugin for VMware VAAI: NFS datastores show 'Unsupported' Hardware Acceleration status in vCenterThu, 19 Feb 2026
- What VAAI offloaded operations are supported by Data ONTAP?Thu, 05 Feb 2026
- Storage vMotion creates Thick provisioned disks even if Thin Provisioned is selectedThu, 29 Jan 2026
- "Consolidation is required" when deleting snapshot on NFS/VAAIMon, 08 Dec 2025
- There is no performance improvement when using VAAI copy offloadWed, 12 Nov 2025
- Unable to upgrade VMware ESXI from 7 x to 8 x due to Missing GUNZIP Checksum VIBSFri, 24 Oct 2025
- How to check the NetApp NFS Plug-in for VMware VAAI is being used?Tue, 23 Sep 2025
- VM disk type displayed as Thin Provision after VAAI is installedThu, 18 Sep 2025
- FlexGroup data not reclaimed after VM deletion/migration using VAAI copy offloadWed, 06 Aug 2025
- NetApp NFS Plug-in for VMware VAAI: 'Thick Provisioning' Option is Unavailable when Provisioning VMsWed, 02 Jul 2025
