How does Active IQ Upgrade Advisor help to perform an ONTAP upgrade or revert ?
Applies to
- ONTAP 9
- Data ONTAP 8 7-mode
- AutoSupport
- Active IQ Upgrade Advisor
- FAS/AFF systems
Answer
The ONTAP Upgrade Advisor is a tool within Active IQ that will provide a plan with steps and commands to successfully perform a ONTAP upgrade or revert. The plan also contains context-sensitive links to the following:
- Pre and post-upgrade checks
- Issues and risk exposures
- ONTAP Release Notes
- Links to shelf module, system, and diagnostic FW
Additional Information
- NetApp Active IQ Digital Advisor Docs Upgrade the ONTAP version by generating an upgrade plan
- Ensure your storage system is up to date
- How to configure AutoSupport
- Is Upgrade Advisor supported with ONTAP Select?
- Changes to Active IQ - Differences in features between Active IQ Classic and Active IQ Digital Advisor
