XCP-KBs
XCP-KBs
Other Resources
- XCP copy shows Datasize discrepancy between source and target due to deduplicationThu, 16 Apr 2026
- Is there a way to fetch the count of open files in the source during copy/syncTue, 07 Apr 2026
- Does XCP Enforce Naming Restrictions or Best Practices for Copy and Sync IDsMon, 30 Mar 2026
- Can the Same XCP Catalog Be Reused on Another VM If the Original XCP VM Crashes?Mon, 30 Mar 2026
- Why dirsize is different between XCP source and destination even for the same dataSun, 29 Mar 2026
- can we bypass required ports for XCP during migrationTue, 24 Feb 2026
- Can I write data to the destination volume during XCP SyncSat, 07 Feb 2026
- XCP sync deleted data created directly on the destination volumeThu, 05 Feb 2026
- XCP scan speed is slower in XCP 1.9.x compared to 1.6.3Sat, 17 Jan 2026
- XCP fails with “ModuleNotFoundError:No module named ‘cffi"Thu, 08 Jan 2026
- XCP for CIFS copy command fails with max_workers must be less than errorTue, 30 Dec 2025
- XCP copy fails with reasion Files were modified deleted while copy was in progressSun, 21 Dec 2025
- XCP Job Fails with Catalog Error Due to File Policy Blocking missing and done Extensions on ONTAPThu, 11 Dec 2025
- XCP final sync task hang with Directory mod time changed reading anywaySun, 07 Dec 2025
- XCP SMB: A process in the process pool was terminated abruptlySat, 06 Dec 2025
- XCP copy fails with ERROR: Error creating index: nfs3 error 13: permission deniedThu, 04 Dec 2025
- Data not in sync from the source after XCP migrationThu, 04 Dec 2025
- What are the best arguments for moving large files with NetApp XCP over CIFS?Mon, 17 Nov 2025
- XCP SMB verify returns failed to get security descriptor error after migrationSun, 09 Nov 2025
- XCP verify Reports different attrs (Mtime) After CopySat, 08 Nov 2025
- NetApp XCP Frequently Asked Questions and ResourcesTue, 14 Apr 2026
- XCP copy fails with message "nfs3 error 27: file too large" because source volume has larger directory size limit than destination columeWed, 01 Apr 2026
- How to write XCP scan output to fileMon, 30 Mar 2026
- XCP copy/show command fails with error "Connection reset by peer"Tue, 24 Mar 2026
- When copying a subset of data over XCP, permissions are incomplete on the destinationFri, 20 Mar 2026
- How to utilize XCP to populate or warm a FlexCache volumeMon, 09 Mar 2026
- xcp license activation fails when online license is usedWed, 25 Feb 2026
- Can I write data to the destination volume during XCP SyncMon, 23 Feb 2026
- NetApp XCP for NFS reports files skipped due to being duplicatesThu, 12 Feb 2026
- XCP Job Fails with Catalog Error Due to File Policy Blocking missing and done Extensions on ONTAPFri, 16 Jan 2026
