NetApp Knowledge Base
What is CPU utilization in ONTAP: Scheduling and Monitoring?
32,475
Visibility:
Votes:
5
Category:
ontap-9
Specialty:
Perf
Last Updated:
Applies to
  • ONTAP 9
Answer
Note:
To determine if CPU utilization is a concern, see KB: How do I know if CPU is causing a performance issue?
  • Each storage controller contains one or more multi-core CPUs.
  • These physical CPU cores are the primary compute resource available to ONTAP for processing work.
  • In addition to CPU cores, ONTAP interacts with other physical hardware such as Ethernet ports, FC ports, disks, and NVRAM.
  • The use of all these physical resources occurs in a highly optimized and parallel manner -- taking into account active requests, resource availability, and the overall activity level of the system.
  • As the interaction between physical resources can be complex and inter-dependent, a measure of CPU being busy (CPU utilization) does not increase linearly with an increase in incoming requests from clients, nor can it be used alone as a measure of the overall system utilization.
  • CPU resources have several unique characteristics that are useful while analyzing the system.
For more detailed information on CPU utilization, see the knowledge base articles below:
Additional Information
additionalInformation_text
New to NetApp?
