NetApp Knowledge Base
What are CPU as a compute resource and the CPU domains in ONTAP 9?
7,184
Visibility:
Votes:
6
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
Answer
  • ONTAP uses a Coarse Symmetric Multiprocessing (CSMP) design which partitions system functions into logical processing domains.
  • Each logical processing domain has a set of rules that govern how and when the logical CSMP domain can be scheduled across physical CPU cores.
  • These rules are designed to ensure that all processing occurs in a safe and efficient manner.
  • The following table describes some of the common logical processing domains, their typical tasks.
  • It also describes if the logical domain can run on one or more CPU cores concurrently, along with any specific scheduling rules:
Domain name
Typical Tasks in Domain
CPU Concurrency
Notes
nwk_exclusive
IP processing, NFS protocol processing
1
Networking code which can only run on a single CPU concurrently
nwk_exempt
IP processing, NFS protocol processing, SMB processing
1+
Maximum number of CPUs is dependent on controller model and ONTAP release
nwk_legacy (pre 9.2)
network (9.2+)
1
storage
SCSI communication
with disks
1+
Concurrency of 1 if less than 6 CPUs
raid
RAID subsystem
1
raid_exempt
RAID subsystem
1+
XOR_Ex
RAID subsystem XOR parity processing
1+
ssan_exempt
SCSI (FCP/iSCSI) processing
1+
Kahuna
Serialized WAFL and anything not in another domain
1
Exclusive with WAFL_Ex (i.e. either Kahuna can be active on 1 CPU or WAFL_Ex can be active on 1+ CPUs, but both cannot be active at the same time)
WAFL_Ex
Parallelized WAFL
1+
Exclusive with Kahuna (i.e. either Kahuna can be active on 1 CPU or WAFL_Ex can be active on 1+ CPUs, but both cannot be active at the same time)
WAFL_MPClean
WAFL
1+
SM_Exempt
SnapMirror
1+
exempt
General parallelized work
1+
hostOS
Tasks owned by the BSD layer including NTP, environmental sensor monitoring, ZAPI handling, autosupport
1+
reserved Reserved based on system performance and capacity requirements.
  • Logical CSMP domains are scheduled to run on physical CPU cores by the ONTAP kernel.
  • The scheduling logic is unique to a given ONTAP release and hardware platform and is tuned to maximize the overall system performance.
  • The level of parallelism seen for a given logical domain varies based on a number of factors, including:
    • Incoming workload rate
    • Type of work being requested
    • ONTAP OS version and more.
Additional Information
Scheduling behaviors:
  • Pinning of heavily used logical domains to physical CPU core to maximize cache efficiency.
  • Shutdown of physical CPU cores at various load points to optimize processing of the run queue.
  • These optimizations might appear to result in an uneven balancing of workload across physical CPU cores.
  • This behavior is by design and is optimized for each specific ONTAP release and platform combination.
