NetApp Knowledge Base
How to measure CPU Utilization in 7mode mode device
557
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • Data ONTAP 8 7-Mode
  • Data ONTAP 7 and earlier
Answer
Verify the CPU utilization with the following commands :
  1. Using sysstat -M 1
netapp> priv set diag
netapp*> sysstat -M 1
ANY1+ ANY2+ ANY3+ ANY4+  AVG  CPU0 CPU1  CPU2  CPU3
93%    80%  36%   15%    56%  38%   32%  82%   72%
Nwk_Excl Nwk_Lg Nwk_Exmpt Protocol Cluster Storage Raid Raid_Ex Target Kahuna
1%         68%     1%       0%        0%      4%     0%  19%      0%    11%
WAFL_Ex(Kahu) WAFL_XClean SM_Exempt Cifs Exempt SSAN_Ex Intr Host Ops/s  CP
80%( 75%)      14%            0%      0%   24%    0%     1%    1%   0    83%
In this example, Average CPU Utilization is 56% and the nwk_legacy domain (max concurrency of 1) is 68%.
  • To analyze for a WAFL bottleneck, Kahuna is 11% and WAFL_Ex is 75%, or 86% in total:
    • As this is < 100%, it is not a bottleneck. However, if it is nearing 100%, it might still not be a concern without other contributing performance indicators.
  • While CPU (logical and physical) utilization is exposed by Data ONTAP, CPU utilization should not be used as a first-order metric for evaluating the overall performance of a system.
    • Instead, the inputs and outputs associated with the requested user work should be the first-order metric.
  • A focus on actual latency for work being serviced (Response Time) and the quantity of operations being processed in terms of IO requests or Bytes (Throughput) is recommended.
  • This measure of performance is relevant to a given workload and abstracts the complex nature of logical and physical CPU scheduling variations.
  1. Using sysstat - x 1
fas01> priv set diag
Warning: These diagnostic commands are for use by NetApp
         personnel only.
fas01*> sysstat -x 1
 CPU    NFS   CIFS   HTTP   Total     Net   kB/s    Disk   kB/s    Tape   kB/s  Cache  Cache    CP  CP  Disk
                                       in    out    read  write    read  write    age    hit  time  ty  util
  2%      0      0      0     104       0      0       0      0       0      0   >60    100%    0%  -     0%
  2%      0      0      0       1       0      0       0      0       0      0   >60    100%    0%  -     0%
  2%      0      0      0       0       0      0      64    771       0      0   >60    100%    1%  T     1%
  2%      0      0      0      99       0      0       0      0       0      0   >60     99%    0%  -     0%
  1%      0      0      0       0       0      0       0      0       0      0   >60    100%    0%  -     0%
  1%      0      0      0       2       0      1       0      0       0      0   >60    100%    0%  -     0%
In this example, CPU Utilization can be viewed from the first column which is 2%.
