NetApp Knowledge Base
ANDU validation script fails on shelves and sensors check on large clusters
1,415
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • Automate Non-Disruptive Upgrade (ANDU)
  • Upgrading to ONTAP prior to 9.10.1
Issue
  • The ANDU process fails during the validation phase on the "shelves and sensors check" task:
::> cluster image show-update-progress
                                              Estimated         Elapsed
Update Phase         Status                   Duration        Duration
Pre-update checks    failed                   00:10:00        00:04:21
Details:
Pre-update Check     Status            Error-Action
Shelves and Sensors  Error             Error: Validation check failed to
check                                  execute properly.
                                       Action: If the problem persists after
                                       retrying, delete the package and
                                       download again
  • The cluster is running an ONTAP version and BMC/SP firmware version that contains the fixes for BUG 1139218 and BUG 1274574.
  • The cluster is very large (20+ nodes with a large number of shelves)
Note: Verify that SP API Service is not the cause by reviewing   Active IQ Wellness Risk: ONTAP reports error when communicating with SP/BMC
New to NetApp?
