NetApp Knowledge Base
The controller temperature (System Outlet) is not readable
1,163
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8300
  • BMC Firmware 13.8
Issue
EMS
3/14/2024 14:17:35  node-01  ERROR  monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 13:17:35  node-01  ERROR  monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 12:17:35  node-01  ERROR  monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 11:17:35  node-01  ERROR  monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 10:17:34  node-01  ERROR  monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 09:17:34  node-01  ERROR  monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 08:17:34  node-01  ERROR  monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 07:17:34  node-01  ERROR  monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 06:17:34  node-01  ERROR  monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 05:17:34  node-01  ERROR  monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 09:18:02  node-01  ERROR  callhome.chassis.hitemp: Call home for CHASSIS OVER TEMPERATURE
Environment status
System Inlet   normal     23 C  0 C  5 C   46 C   49 C
CX5 Inlet      normal     37 C  0 C  5 C   60 C   70 C
System Outlet  failed     -- C  0 C  5 C   58 C   61 C
NVMe Temp      normal     25 C  0 C  5 C   60 C   70 C
LED1 Temp      normal     23 C  0 C  3 C   43 C   46 C
LED2 Temp      normal     23 C  0 C  3 C   43 C   46 C
MP Temp1       normal     21 C  0 C  5 C   45 C   48 C
SP-LATEST-IPMI
Log Collection Time: Thu Mar 21 01:55:13 2024
Self Test: (run for 0 sec)
    Selftest: passed
Sensor Reading: (run for 1 sec)
    PilotIV        | 00h | ok  |  0.1 | Dynamic MC @ 20h
    PVCCIN_CPU0    | 01h | ok  | 21.1 | 1.77 Volts
    PVCCIN_CPU1    | 02h | ok  | 21.1 | 1.77 Volts
    PVDDQ_ABC      | 03h | ok  | 21.1 | 1.21 Volts
    PVDDQ_DEF      | 04h | ok  | 21.1 | 1.21 Volts
    PVDDQ_GHI      | 05h | ok  | 21.1 | 1.21 Volts
    PVDDQ_KLM      | 06h | ok  | 21.1 | 1.21 Volts
    P1V05_PCH      | 07h | ok  | 21.1 | 1.03 Volts
    System_Inlet   | 10h | ok  |  7.1 | 22 degrees C
    CX5_Inlet      | 11h | ok  |  7.2 | 37 degrees C
    System_Outlet  | 12h | ns  |  7.3 | No Reading
    NVMe_Temp      | 13h | ok  |  7.4 | 25 degrees C
New to NetApp?
