NetApp Knowledge Base
System FAN RPM is high and the noise is loud
2,048
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS System
  • AFF System
Issue
  • Noise from FAN is loud.
  • system node environment sensors show indicates that the FAN speed of the affected node is higher than that of the other nodes.
  • SP-LATEST-IPMI log in AutoSupport also indicates that the FAN speed of the affected node is higher than that of the other nodes.
Example:
  • The affected node:
FAN1:
Fan1_Status      | 0x0        | discrete   | Ready      | na        | na        | na        | na
Fan1_Current     | 7.900      | Amps       | ok         | 0.000     | 0.500     | 10.000    | 12.000
Fan1_Speed1      | 8400.000   | RPM        | ok         | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan1_Speed2      | 8400.000   | RPM        | ok         | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan1_Speed3      | 8350.000   | RPM        | ok         | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan1_Speed4      | 8400.000   | RPM        | ok         | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan1_Volt1       | 11.940     | Volts      | ok         | 10.560    | 11.160    | 12.840    | 13.440
  • Another node:
FAN1:
Fan1_Current     | 1.250      | Amps       | ok         | 0.000     | 0.500     | 10.000    | 12.000
Fan1_Speed1      | 4200.000   | RPM        | ok         | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan1_Speed2      | 4250.000   | RPM        | ok         | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan1_Speed3      | 4250.000   | RPM        | ok         | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan1_Speed4      | 4200.000   | RPM        | ok         | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan1_Volt1       | 12.000     | Volts      | ok         | 10.560    | 11.160    | 12.840    | 13.440
  • The amber light of Chassis may be lighted.
New to NetApp?
