NetApp Knowledge Base
system fails to boot with "System DIMM configuration is not supported"
2,695
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8200
  • FAS8020
  • FAS2620
  • AFF8080
  • FAS8300
  • AFF A400
Issue
The storage system fails to boot and halts by itself. The following error message is reported when the storage system boots:
Example:
System DIMM configuration is not supported on FAS8200
Please check the DIMM placement on SLOT-1 SLOT-2 ...
Halting...
Example:
DIMM missing in slot DIMM-2
DIMM missing in slot DIMM-3
System DIMM configuration is not supported by FAS8020
Example:
System DIMM configuration is not supported on FAS2620
Please check the DIMM placement on SLOT-1 ...
Halting...
New to NetApp?
