Sensor 7 or sensor 13 over-temperature warning on NS224
- 1,848
- Visibility:
- Public
- Votes:
- 0
- Category:
- disk-shelves
- Specialty:
- hw
- Last Updated:
- 2/15/2024, 11:41:09 PM
Applies to
- NS224 shelf
- NSM100 module running firmware version prior to 02.10
Issue
- Over-temperature on sensor 7 or 13, which is the CPU sensor on the NSM module A or B
[node_name: dsa_worker4: ses.status.temperatureWarning:alert]: NS224NSM100 (S/N 123456789) shelf 0 on channel 0x temperature warning for Temperature sensor 7: non-critical status; overtemperature warning. Current temperature: 88 C
(190 F). This element is on the unknown location
[node_name: dsa_worker4: ses.status.temperatureWarning:alert]: NS224NSM100 (S/N 123456789) shelf 0 on channel 0x temperature warning for Temperature sensor 13: non-critical status; overtemperature warning. Current temperature: 88 C
- Hourly EMS error:
[node_name: statd: monitor.shelf.warning:error]: Fault reported on disk storage shelf attached to channel 0x. Check fans, power supplies, disks, and temperature sensors.
- Storage show fault AutoSupport output example:
Enclosure Status: non-critical
Channel: 0x
Shelf: 0
Shelf Type: NS224NSM100
Module Type: NSM100
Temperature Sensors:
Element Status Status Bytes Status Descriptions
1: OK 01,00,2A,00
12: OK 01,00,2E,00
13: NONCRITICAL 03,00,6C,04 OT WARNING
14: OK 01,00,3C,00
17: OK 01,00,3D,00
Enclosure:
1: OK 01,00,02,00 FAIL
- ENVIRONMENT AutoSupport output example:
Channel: 0x
Shelf: 10
SES device path: local access: 0x.10.1.99
Module type: NSM100; monitoring is active
Shelf status: non-critical condition
SES Configuration, shelf 10:
Temperature Sensor installed element list: 1, 2, 3, ...15, 16, 17; with error: 13
Shelf temperatures by element:
[1] 19 C (66 F) (ambient) Normal temperature range
[12] 22 C (71 F) Normal temperature range
[13] 88 C (190 F) Overtemperature warning!
::> storage shelf show
output example:
Temperature:
-- Thresholds °C --
Temp Is Low Low High High Operational
ID °C Ambient Crit Warn Crit Warn Status Sensor Location
1 19 true 0 5 52 47 normal ambient temp sensor on ODP board
2 24 false 0 5 60 55 normal temp sensor on midplane left
7 35 false 0 5 90 85 normal CPU package on top module
12 22 false 0 5 65 60 normal bottom module temp sensor near midplane
13 88 false 0 5 90 85 over-temperature CPU package on bottom module
14 45 false 0 5 85 80 normal Ethernet port 1 on bottom module
storage fault
output example:
::> system node run -nodde node_name -command storage show fault
1: OK 01,00,27,00
6: OK 01,00,33,00
7: NONCRITICAL 03,00,6C,04 OT WARNING
8: OK 01,00,4C,00
17: OK 01,00,44,00
