NetApp Knowledge Base
SP heart beat LED on with no failure detected
392
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8200
Issue
  • system led show all shows that SP heart beat LED is on:
SP01-01*> system led show all
FRU LED ID 1 is off
FRU LED ID 2 is off
FRU LED ID 3 is off
FRU LED ID 4 is on
FRU LED ID 5 is off
FRU LED ID 28 is off
Display status of the specified <FRU-LED-ID>.
<FRU-LED-ID>:
        1 - SP Controller Fault LED
        2 - SP Chassis Locate LED
        3 - SP System Fault LED
        4 - SP Heartbeat LED
        5 - SP Fan 1 Fault LED
        28 - SP RTC Battery Fault LED (Coin Cell Battery)
        all others are not valid
  • service-event show with no failure detected from both sp prompt and ONTAP prompt:
SP01-01*>system service-event show
   ID   FRU Description                                              Fault Reason
Fault Lights On:
cluster::> system controller service-event show -instance
There are no entries matching your query.
New to NetApp?
