NetApp Knowledge Base
SAS port PHY disabled even after cable and IOM replacement
1,329
Visibility:
Votes:
2
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS systems
  • AFF systems
Issue
  • DegradedOnlinePort alert is reported for a SAS port:
[node-name: nchmd: hm.alert.raised:alert]: Alert Id = DegradedOnlinePort_Alert , Alerting Resource = 0c raised by monitor node-connect
Cluster::> system health alert show
               Node: Node-01
           Alert ID: DegradedOnlinePort_Alert
           Resource: Port 0c
           Severity: Major
    Indication Time: Mon Dec 15 12:11:32 2025
           Suppress: false
        Acknowledge: false
     Probable Cause: SAS port 0c on controller Node-01 has 3 disabled
                     PHYs.
    Possible Effect: Inactive PHYs might cause degraded link performance.
 Corrective Actions: 1. Verify that SAS port 0c has disabled PHYs by using the "storage port show -node node-01 -port 0c" command.
                     2. If the disk shelves connected to port 0c have multiple path to the node, reset port 0c by using the (privilege: advanced) "storage port reset -node node-01 -port 0c" command.
                     3. Verify that the physical cable connection is secure and operational. If the disk shelves are multipathed, reseat the cable.
                     4. If the connected disk shelf is multipathed, replace
                     the SAS cable.
Cluster::> system health subsystem show
Subsystem         Health
SAS-connect       degraded
Environment       ok
Memory            ok
Service-Processor ok
  • From sysconfig -a logs, it is found that one of the PHYs is disabled:
  slot 0: SAS Host Adapter 0d (Broadcom SAS3616W rev. 2, SAS, <UP>)
       Firmware rev:      12.00.00.00
       NVDATA rev:        12.03.01.02
       Base WWN:          5:XXXXX:XXXXX:4e
       Temperature:       Not Available
       Phy State:         [0] Enabled, 12.0 Gb/s
                          [1] Enabled, 12.0 Gb/s
                          [2] Enabled, 12.0 Gb/s
                          [3] Disabled
  • The PHY remains disabled, even after replacing the cable and IOM connected to it.
New to NetApp?
