NetApp Knowledge Base
Is it possible to perform a disk rebuild test in ONTAP without causing hardware damage?
214
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • NetApp ONTAP 9
  • Disk management and testing
Yes, you can perform a disk rebuild test in ONTAP without causing hardware damage by using the disk fail and disk unfail commands. Here is the procedure:
  1. Failing the Disk:
    • Use the disk fail command to simulate a disk failure. This command can be used with or without the -i option.
      • Without -i: The disk will be gradually detached using Disk Copy.
      • With -i: The disk will be immediately detached.
Example:
::> storage disk fail -disk <disk_name>
  1. Unfailing the Disk:
    • After the failout is complete, you can return the disk to its normal status using the disk unfail command.
    • This requires setting the privilege level to advanced.
Example:
::> set advanced
::*> storage disk unfail -disk <disk_name>
New to NetApp?
