NetApp Knowledge Base
Is it possible to replace small drives with bigger ones without downsizing them?
1,372
Visibility:
Votes:
0
Category:
disk-drives
Specialty:
hw
Last Updated:
Applies to
  • Disk downsizing
  • RAID groups
Answer
No.
  • NetApp Write Anyware File Layout (WAFL) uses Virtual Block numbers (VBNs) when creating RAID groups and aggregates.
  • The VBNs used by each disk are "fixed" in the RAID group so, if a disk is replaced with a bigger one, the amount of VBNs will remain.
  • The empty space in the bigger drive won't be used by WAFL for new VBNs. No data will be stored in the "available" space.
  • The aggregate with mixed drives should be destroyed and recreated again with the correct ones.
