NetApp Knowledge Base
How to Troubleshoot DS460C Disk Shelf Drawer Controller Module (DCM) Faults after ONTAP upgrade to 9.5 and Firmware upgrade
1,923
Visibility:
Votes:
1
Category:
disk-shelves
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9.5p5 and lower
  • DS460C Disk Shelf
  • IOM12 FW 230 and lower
Symptom
  • During an upgrade to  ONTAP 9.5, a IOM12 Firmware update on the DS460C disk shelf also occurs.  This may lead to a shelf fault. An amber light will appear on the disk shelf showing a fault.
  • Running the command "storage show fault -v" will show the following faults:
Enclosure:
Element Status         Status Bytes  Status Descriptions
  1: OK                01,00,02,00   FAIL
  Drawers Control Module:
  1 [IOM12 A]    : OK                01,00,01,00   REPORT
  2 [IOM12 A]    : OK                01,00,01,00   REPORT
  3 [IOM12 A]    : OK                01,40,01,00   FAIL, REPORT
  4 [IOM12 A]    : OK                01,00,01,00   REPORT
  5 [IOM12 A]    : OK                01,00,01,00   REPORT
  6 [IOM12 B]    : OK                01,00,01,00   REPORT
  7 [IOM12 B]    : OK                01,00,01,00   REPORT
  8 [IOM12 B]    : OK                01,00,01,00   REPORT
  9 [IOM12 B]    : OK                01,00,01,00   REPORT
 10 [IOM12 B]    : OK                01,00,01,00   REPORT
New to NetApp?
