NetApp Knowledge Base
Fan failure detected on both nodes even after replacing controller
390
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
FAS2750
Issue
  • ses.status.fanError:EMERGENCY and  monitor.globalStatus.critical:EMERGENCY]: Multiple fans has failed recorded on both nodes
[?]  Sun Jul 13 04:44:28 +0900 [node-A: dsa_worker3: ses.status.fanError:EMERGENCY]: DS224-12 (S/N SHJXXXXXXXXXX32) shelf 0 on channel 0b cooling fan error for Cooling element 2: critical status. This module is on the rear of the shelf on the lower left power supply.
[?]  Sun Jul 13 04:44:43 +0900 [node-A: env_mgr: monitor.fan.warning:notice]: multiple fans have failed. Replace it to avoid overheating
[?]  Sun Jul 13 04:44:46 +0900 [node-A: dsa_worker1: ses.status.fanError:EMERGENCY]: DS224-12 (S/N SHJXXXXXXXXXX32) shelf 0 on channel 0b cooling fan error for Cooling element 3: critical status. This module is on the rear of the shelf on the lower right power supply.
[?]  Sun Jul 13 04:45:00 +0900 [node-A: monitor: monitor.globalStatus.critical:EMERGENCY]: Multiple fans has failed. Disk shelf fault.
[?]  Sun Jul 13 04:45:13 +0900 [node-A: dsa_worker3: ses.status.fanError:EMERGENCY]: DS224-12 (S/N SHJXXXXXXXXXX32) shelf 0 on channel 0b cooling fan error for Cooling element 4: critical status. This module is on the rear of the shelf on the lower right power supply.
[?]  Sun Jul 13 04:45:43 +0900 [node-A: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Multiple fans have failed
[?]  Sun Jul 13 04:44:28 +0900 [node-B: dsa_worker2: ses.status.fanError:EMERGENCY]: DS224-12 (S/N SHJXXXXXXXXXX32) shelf 0 on channel 0a cooling fan error for Cooling element 2: critical status. This module is on the rear of the shelf on the lower left power supply.
[?]  Sun Jul 13 04:44:33 +0900 [node-B: env_mgr: monitor.fan.warning:notice]: multiple fans have failed. Replace it to avoid overheating
[?]  Sun Jul 13 04:44:46 +0900 [node-B: dsa_worker0: ses.status.fanError:EMERGENCY]: DS224-12 (S/N SHJXXXXXXXXXX32) shelf 0 on channel 0a cooling fan error for Cooling element 3: critical status. This module is on the rear of the shelf on the lower right power supply.
[?]  Sun Jul 13 04:45:00 +0900 [node-B: monitor: monitor.globalStatus.critical:EMERGENCY]: Multiple fans has failed. Disk shelf fault.
[?]  Sun Jul 13 04:45:13 +0900 [node-B: dsa_worker2: ses.status.fanError:EMERGENCY]: DS224-12 (S/N SHJXXXXXXXXXX32) shelf 0 on channel 0a cooling fan error for Cooling element 4: critical status. This module is on the rear of the shelf on the lower right power supply.
[?]  Sun Jul 13 04:45:33 +0900 [node-B: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Multiple fans have failed
  • Critical fan errors are also reported from STORAGE-FAULT and ENVIRONMENT on both nodes
STORAGE-FAULT:
Enclosure Status: critical
Channel: 0a
Shelf: 0
Shelf Type: DS224-12
Product Serial Number: SHJXXXXXXXXXX32
Module Type: IOM12E
Fans:
Element Status         Status Bytes  Status Descriptions
  1: CRITICAL          02,02,EB,A7
  2: CRITICAL          02,02,EB,A7
  3: CRITICAL          02,02,EB,A7
  4: CRITICAL          02,02,EB,A7
ENVIRONMENT:
Channel: 0a
Shelf: 0
SES device path: local access: 0b.00.99
Module type: IOM12E; monitoring is active
Shelf status: critical condition
Cooling Unit installed element list: 1, 2, 3, 4; with error: 1, 2, 3, 4
Cooling Units by element:
   [1] 7470 RPM
   [2] 7470 RPM
   [3] 7470 RPM
   [4] 7470 RPM
  • PSU fans show normal status in SP-LATEST-IPMI, but SNMP Bad Fan Count indicates MULTI_FAILED and PSU_FAN shows FAIL_4.
hsamcmd --fault-show-all
tag  origin  fld                                     fault reason                                    count  time
1    bmc     /chassis-1                              SAS Expander has set the Chassis LED ON         1      Sat Jul 12 19:43:36 2025
SNMP Bad Fan Count                      MULTI_FAILED
PSU1 Fan 1               normal          7470 RPM      --          --          --          --
PSU1 Fan 2               normal          7470 RPM      --          --          --          --
PSU1 Inlet Temp          normal            23 C         0 C         5 C        57 C        62 C
PSU1 Hotspot Temp        normal            24 C         0 C         5 C        90 C       100 C
PSU2 Present                            PRESENT
PSU2 5V                  normal          5110 mV       --          --          --          --
PSU2 12V                 normal         12260 mV       --          --          --          --
PSU2 5V Curr             normal          3350 mA       --          --          --          --
PSU2 12V Curr            normal          7770 mA       --          --          --          --
PSU2 Fan 1               normal          7470 RPM      --          --          --          --
PSU2 Fan 2               normal          7470 RPM      --          --          --          --
PSU2 Inlet Temp          normal            29 C         0 C         5 C        57 C        62 C
PSU2 Hotspot Temp        normal            30 C         0 C         5 C        90 C       100 C
PSU_FAN                                 FAIL_4
  • Actions taken but not resolved:
    1. Rebooted BMC on both nodes.
    2. Replaced PSU1/PSU2.
    3. Replaced Controller A.
    4. Reinserted Controller B
New to NetApp?
