NetApp Knowledge Base
FAS9000 nvram.battery.sensor.unreadable causes node shutdown
104
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • FAS9000
  • SP 4.11
  • ONTAP 9
Issue
A FAS9000 node reboots due to unreadable battery sensors:
[cluster1-04: env_mgr: nvram.battery.sensor.unreadable:EMERGENCY]: The NVRAM battery state cannot be determined because the 'Bat Cycle Count' sensor is unreadable. To prevent data loss, the system will shut down in 5 minutes.
[cluster1-04: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Cycle Count' unreadable) CRITICAL.
New to NetApp?
