NetApp Knowledge Base
FAS9000 EMS errors after environmental shutdown and chassis fan replacement
770
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • AFF A700 / FAS9000
  • ONTAP 9
  • SP firmware below 4.7
Issue
After a multi-fan failure occurs which results in an environmental shutdown, EMS messages indicate continued fan field replaceable unit failure despite being replaced.
cluster::*> event show -node local -event *fan*|*psu*
Time                Node             Severity      Event
10/25/2017 12:00:00 cluster
                                     ALERT         monitor.fan.failed: Multiple fans has failed: FanA2 F4, FanA2 F3, FanA2 F2, FanA2 F1. <<<<<<<<<<<<<<<<< Generated when PSU 3 cable removed and inserted back after some time .
10/25/2017 11:52:00 cluster
                                     EMERGENCY     monitor.globalStatus.critical: Controller failover of nbs-plat-9000-122 is not possible: Controller Failover takeover disabled. Multiple fans has failed: FanA2 F4, FanA2 F3, FanA2 F2, FanA2 F1.
10/25/2017 11:37:00 cluster
                                     EMERGENCY     monitor.globalStatus.critical: Controller failover of nbs-plat-9000-122 is not possible: Controller Failover takeover disabled. Multiple fans has failed: FanA2 F4, FanA2 F3, FanA2 F2, FanA2 F1. Power Supply Status Critical: PSU3.
10/25/2017 11:09:00 cluster
10/25/2017 11:00:00 cluster
                                     EMERGENCY     monitor.globalStatus.critical: Controller failover of nbs-plat-9000-122 is not possible: Controller Failover takeover disabled. Multiple fans has failed: FanA2 F4, FanA2 F3, FanA2 F2, FanA2 F1. Power Supply Status Critical: PSU1.
cluster::> sp show
                               IP           Firmware
Node          Type Status      Configured   Version   IP Address
cluster-01    SP   online      true         4.6       10.0.0.1
cluster-02    SP   online      true         4.6       10.0.0.2
New to NetApp?
