NetApp Knowledge Base
DS2246 Shelf fans critical status running at high speed
1,520
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • AFF systems
  • FAS systems
  • DS2246
  • MetroCluster
Issue
  • Autosupport alerts generated for SHELF_FAULT and SHELF COOLING UNIT FAILED
[Node-01: statd: monitor.shelf.fault:alert]: Critical fault reported on disk storage shelf attached to channel 3a. Check fans, power supplies, disks, and temperature sensors.
[Node-01: statd: callhome.shlf.fault:error]: Call home for SHELF_FAULT
[Node-01: monitor: monitor.globalStatus.critical:EMERGENCY]: Disk shelf fault.
[Node-01: dsa_worker5: callhome.shlf.fan:EMERGENCY]: Call home for SHELF COOLING UNIT FAILED
  • "environment status" shows fans are running at very high speed even though the temperature is normal in the server room
Shelf: 10
	SES device path: local access: 3a.125L103
	Module type: IOM6; monitoring is active
	Shelf status: critical condition
	SES Configuration, shelf 10:
	 logical identifier=0x500a09800385ace9
	 vendor identification=NETAPP
	 product identification=DS2246
[truncated...]
	Cooling Unit installed element list: 1, 2, 3, 4; with error: 1, 2, 3, 4
	Cooling Units by element:
	  [1] 8000 RPM
	  [2] 8020 RPM
	  [3] 8000 RPM
	  [4] 8000 RPM
Troubleshooting Performed:
  • Shelf Firmware is on latest version
  • SP FW upgraded to latest version
  • IOM, PSU and Fans have all been individually reseated
New to NetApp?
