NetApp Knowledge Base
CriticalFanXFruFaultAlert is reported due to chassis fan failure - sensor reports critical
1,179
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • Chassis FAN
Issue
  • The following errors are reported for a fan module in event logs:
[Node1: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: Fan2_2 (failed)
[Node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Fan2_2
[Node1: monitor: monitor.globalStatus.critical:EMERGENCY]: One fan has failed: SysFan2 F2.
[Node1: cphmd: hm.alert.raised:alert]: Alert Id = CriticalFan2FruFaultAlert , Alerting Resource = 021XXXXXXXX882 raised by monitor chassis
[Node1: mgwd: callhome.hm.alert.critical:alert]: Call home for Health Monitor process cphm: CriticalFan2FruFaultAlert[021XXXXXXXX882].
  • The SP-LATEST-IPMI section of autosupport shows critical status for the affected fan:
hsamcmd --fault-show-all
tag  origin  fld                      fault reason                                    count  time
1    0x5     /chassis-1/fan-2         ipmi Fan2_Speed2 lower non-critical             1      Tue May  9 19:20:38 2023
2    0x5     /chassis-1/fan-2         ipmi Fan2_Speed2 lower critical                 1      Tue May  9 19:20:38 2023
FAN2:
Fan2_Status      | 0x0        | discrete   | Ready      | na        | na        | na        | na
Fan2_Current     | 6.150      | Amps       | ok         | 0.000     | 0.500     | 10.000    | 12.000
Fan2_Speed1      | 8300.000   | RPM        | ok         | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan2_Speed2      | 0.000      | RPM        | cr         | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan2_Speed3      | 8300.000   | RPM        | ok         | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan2_Speed4      | 8250.000   | RPM        | ok         | 1000.000  | 1250.000  | 9750.000  | 10000.000
Or
Fan1_1           | 70h | ok  | 29.1 | 9000 RPM
Fan2_1           | 71h | lcr | 29.2 | 0 RPM
Fan3_1           | 72h | ok  | 29.3 | 9000 RPM
Fan4_1           | 73h | ok  | 29.4 | 9000 RPM
Fan1_2           | 74h | ok  | 29.1 | 9100 RPM
Fan2_2           | 75h | ok  | 29.2 | 9000 RPM
Fan3_2           | 76h | ok  | 29.3 | 9000 RPM
Fan4_2           | 77h | ok  | 29.4 | 9000 RPM
New to NetApp?
