NetApp Knowledge Base
Call home for CLUSTER NETWORK DEGRADED Frequent Link Flapping
5,251
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF systems
  • ASA systems
  • FAS systems
Issue
  • The cluster port link is flapping causing the cluster network to be degraded and the following events are reported in the system:
[Node-02: intr: netif.linkDown:info]: Ethernet e0a: Link down, check cable.
[Node-02: vifmgr: vifmgr.portdown:notice]: A link down event was received on node Node-02, port e0a.
[Node-02: vifmgr: vifmgr.clus.linkdown:EMERGENCY]: The cluster port e0a on node Node-02 has gone down unexpectedly.
[Node-02: intr: netif.linkUp:info]: Ethernet e0a: Link up.
[Node-02: vifmgr: vifmgr.portup:notice]: A link up event was received on node Node-02, port e0a.
[Node-02: vifmgr: vifmgr.port.monitor.failed:error]: The "link_flapping" health check for port e0a (node Node-02) has failed. The port is operating in a degraded state.
[Node-02: vifmgr: callhome.clus.net.degraded:alert]: Call home for CLUSTER NETWORK DEGRADED: Frequent Link Flapping - Cluster port e0a on node Node-02 has experienced multiple link down notifications.
  • The cluster port is degraded due to the link flaps:
Cluster::*> network port show -health-status degraded -fields health-degraded-reasons
node       port health-degraded-reasons
Node-02    e0a  link_flapping
  • The below alert is reported in the event logs when the link between the cluster port and cluster switch goes down:
[Node-01: cshmd: hm.alert.raised:alert]: Alert Id = ClusterSwitchConnectivity_Alert , Alerting Resource = Node-02 raised by monitor ethernet-switch
[Node-01: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process cshm: ClusterSwitchConnectivity_Alert[Node-02].
New to NetApp?
