NetApp Knowledge Base
Amber fault LED is on without hardware failure
8,563
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9
  • FAS/AFF Systems
  • Internal disk shelves
Issue
  • The fault LED is lit on a disk but there are no issues reported about the disk.
  • There is no error in system controller service-event show output:
cluster1::> system controller service-event show
This table is currently empty.
  • The amber LED persists even after turning it off manually as mentioned in Disk has amber light without error.
  • Reseating the affected drive does not change the LED state.
New to NetApp?
