NetApp Knowledge Base
Amber attention LED illuminated during NV battery learning cycle
282
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • AFF A50 / FAS50
  • AFF C30/C60 / AFF A30
  • FAS2750
Issue
  • The controller's attention LED is illuminated and turns off automatically after several hours.
  • The issue occurs during battery learning cycle in events all.
Record 896: Mon Mar 23 00:05:20.133964 2026 [IPMI.notice]: 02df | 02 | EVT: 6f06ffff | Bat_Status | Assertion Event, "Learn Cycle"
Record 897: Mon Mar 23 00:05:31.802421 2026 [IPMI.notice]: 02e0 | 02 | EVT: 6f02ffff | PCM_Status | Assertion Event, "Fault"
Record 898: Mon Mar 23 05:06:10.670291 2026 [BMC.notice]: Battery learning cycle is a success  
Record 899: Mon Mar 23 05:06:32.113765 2026 [IPMI.notice]: 02e1 | 02 | EVT: ef06ffff | Bat_Status | Deassertion Event, "Learn Cycle"
Record 900: Mon Mar 23 05:06:43.843580 2026 [IPMI.notice]: 02e2 | 02 | EVT: ef02ffff | PCM_Status | Deassertion Event, "Fault"
tag  origin  fld                                     fault reason                                    count  time
1    bmc     /chassis-1/controller-a/nvbatt-1        Bat_Lrn_Active                                  1      Mon May 18 00:05:22 2026
Fault Lights On:
/chassis-1        1
/chassis-1/controller-a        1
/chassis-1/controller-a/nvbatt-1                                                        1
Record 1092: Sat Sep 19 12:00:13.679798 2026 [IPMI.notice]: 02b6 | 02 | EVT: 0301ffff | Bat_Lrn_Active | Assertion Event, "State Asserted"
Record 1093: Sat Sep 19 17:41:34.860277 2026 [IPMI.notice]: 02b7 | 02 | EVT: 0300ffff | Bat_Lrn_Active | Assertion Event, "State Deasserted"
  • SP-LATEST-SYSLOG reports attention LED off when learning cycle complete:
Aug  4 05:06:20 BMC01 hsam[1391]: HSAM OS(bmc):cmd(clr) FLD(nvbatt-1):fault(Bat_Lrn_Active)
Aug  4 05:06:21 BMC01 hsam[1391]: FRU /chassis-1 LED off
Aug  4 05:06:21 BMC01 hsam[1391]: FRU /chassis-1/controller-a LED off
New to NetApp?
