NetApp Knowledge Base
AFF / FAS System-level diagnostics fail to identify X1148A 100GbE NIC
611
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • AFF A320
  • AFF A400
  • FAS8700
  • FAS8300
  • ONTAP 9.7P8 and earlier
Issue
  • system-level diagnostics fails to correctly identify some X1148A 100GbE network interface cards (NIC) during the system scan.
  • As a result, diagnostic tests cannot be performed on the X1148A NIC.
  • The following is an example of the error message during the system scan:
PCIE: FAILED
Unsupported PCIE on slot 1
Slot     PN                          SN                          Description
1        MCX516A-CCAT_C21            MT1923K19668                None
New to NetApp?
