NetApp Knowledge Base
AFF A900: CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU1 PSU3
119
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
6/4/2025, 5:19:53 AM
Applies to
  • AFF A900
  • BMC 16.3
Issue
  • EMS event log reports the following alert
Thu Oct 10 12:09:57  [Node01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 AC In Volt is Unreadable
Thu Oct 10 12:09:57  [Node01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 AC In Curr is Unreadable
Thu Oct 10 12:09:57  [Node01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 12V Out Volt is Unreadable
Thu Oct 10 12:09:57  [Node01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 12V Out Curr is Unreadable
Thu Oct 10 12:09:57  [Node01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 3 is degraded: PSU3 AC In Volt is Unreadable
Thu Oct 10 12:09:57  [Node01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 3 is degraded: PSU3 AC In Curr is Unreadable
Thu Oct 10 12:10:00  [Node01: monitor: monitor.globalStatus.critical:EMERGENCY]: Power Supply Status Critical: PSU1, PSU3.
Thu Oct 10 12:10:04  [Node01: power_low_monitor: monitor.chassisPower.degraded:alert]: Chassis power is degraded: Power Supply Status Critical: PSU1, PSU3.
Thu Oct 10 12:10:04  [Node01: power_low_monitor: callhome.chassis.power:error]: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU1, PSU3.
  • SEL logs
Record 209: Thu Oct 10 03:13:29.977861 2024 [BMC.notice]: No response from battery charger
Record 210: Thu Oct 10 03:13:56.925942 2024 [IPMI.emergency]: env_mgr triggers OS halt:Multiple fans failed
Record 211: Thu Oct 10 03:15:12.090204 2024 [IPMI.emergency]: Rebooting BMC to recover the non-readable sens
New to NetApp?
