NetApp Knowledge Base
AFF A400/FAS8300 Chassis temperature is too hot: Multiple Internal Temp sensors are unreadable
2,936
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • AFF-A400
  • AFF-C400
  • FAS8300
  • FAS8700
Issue
  • event log show reports multiple sensors unreadable errors.
node1  ALERT         nvmem.battery.notPresent: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
node1  ERROR         callhome.chassis.ps.degraded: Call home for CHASSIS POWER SUPPLY DEGRADED: PS 1
node1  EMERGENCY     monitor.globalStatus.critical: Power Supply Status Critical: PSU2, PSU1.
node1  EMERGENCY     callhome.chassis.overtemp: Call home for CHASSIS OVER TEMPERATURE SHUTDOWN
node1  EMERGENCY     callhome.battery.failure: Call home for BATTERY (not present) CRITICAL.
node1  ERROR         callhome.chassis.power: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU2, PSU1.
node1  ALERT         monitor.chassisPower.degraded: Chassis power is degraded: Power Supply Status Critical: PSU2, PSU1.
node1  EMERGENCY     monitor.shutdown.chassisOverTemp: Chassis temperature is too hot: Multiple Internal Temp sensors are unreadable. System will be shutdown in 10 minutes
  • Multiple sensors are not available or invalid with non-responding serial console on node:
::*> node run -node node1 -command environment status chassis list-sensors
Node: node1
Sensor Name              State          Current    Critical     Warning     Warning    Critical
                                        Reading       Low         Low         High       High
NVDIMM0 Health                            GOOD
LED1 Temp                not_available     -- C         0 C         3 C        43 C        46 C
LED2 Temp                not_available     -- C         0 C         3 C        43 C        46 C
MP Temp1                 not_available     -- C         0 C         5 C        45 C        48 C
MP Temp3                 not_available     -- C         0 C         5 C        45 C        48 C
Mezz Temp1               invalid           -- C         0 C         5 C        80 C        85 C
Mezz Temp2               invalid           -- C         0 C         5 C        54 C        57 C
PSU1 VIN                 invalid           -- mV    90480 mV    93600 mV    261040 mV    263120 mV
PSU1 VOUT                invalid           -- mV    11336 mV    11440 mV    12948 mV    13156 mV
PSU1 Curr IIN            invalid           -- mA        0 mA       --        9984 mA    12012 mA
PSU1 IOUT                invalid           -- mA        0 mA       --       130000 mA    132000 mA
PSU1 PIN                 invalid           -- mW     7100 mW    14200 mW    1611700 mW    1796300 mW
PSU1 POUT                invalid           -- mW     7100 mW    14200 mW    1611700 mW    1796300 mW
PSU1 Inlet               invalid           -- C         0 C        --          58 C        63 C
PSU1 Hot                 invalid           -- C         0 C        --         100 C       105 C
PSU1 FB Hot              invalid           -- C         0 C        --         100 C       105 C
PSU1 FAN                 not_available     -- RPM     800 RPM    1200 RPM      --          --
PSU2 VIN                 invalid           -- mV    90480 mV    93600 mV    261040 mV    263120 mV
PSU2 VOUT                invalid           -- mV    11336 mV    11440 mV    12948 mV    13156 mV
PSU2 Curr IIN            invalid           -- mA        0 mA       --        9984 mA    12012 mA
PSU2 IOUT                invalid           -- mA        0 mA       --       130000 mA    132000 mA
PSU2 PIN                 invalid           -- mW     7100 mW    14200 mW    1611700 mW    1796300 mW
PSU2 POUT                invalid           -- mW     7100 mW    14200 mW    1611700 mW    1796300 mW
PSU2 Inlet               invalid           -- C         0 C        --          58 C        63 C
PSU2 Hot                 invalid           -- C         0 C        --         100 C       105 C
PSU2 FB Hot              invalid           -- C         0 C        --         100 C       105 C
PSU2 FAN                 invalid           -- RPM     800 RPM    1200 RPM      --          --
Fan1_1                   not_available     -- RPM     600 RPM     900 RPM      --          --
Fan1_2                   not_available     -- RPM     600 RPM     900 RPM      --          --
Fan2_1                   not_available     -- RPM     600 RPM     900 RPM      --          --
Fan2_2                   not_available     -- RPM     600 RPM     900 RPM      --          --
Fan3_1                   not_available     -- RPM     600 RPM     900 RPM      --          --
Fan3_2                   not_available     -- RPM     600 RPM     900 RPM      --          --
Fan4_1                   not_available     -- RPM     600 RPM     900 RPM      --          --
Fan4_2                   not_available     -- RPM     600 RPM     900 RPM      --          --
  • From BMC CLI "bmc log debug" output, several sensor status are "na".
[2023-07-04 20:27:26.617] CX5_Temp1        | na         | degrees C  | na    | na        | 0.000     | 5.000     | 80.000    | 85.000    | na
[2023-07-04 20:27:26.617] CX5_Temp2        | na         | degrees C  | na    | na        | 0.000     | 5.000     | 80.000    | 85.000    | na
[2023-07-04 20:27:26.617] LED1_Temp        | na         | degrees C  | na    | na        | 0.000     | 3.000     | 43.000    | 46.000    | na
[2023-07-04 20:27:26.617] LED2_Temp        | na         | degrees C  | na    | na        | 0.000     | 3.000     | 43.000    | 46.000    | na
[2023-07-04 20:27:26.617] MP_Temp1         | na         | degrees C  | na    | na        | 0.000     | 5.000     | 45.000    | 48.000    | na
[2023-07-04 20:27:26.667] MP_Temp3         | na         | degrees C  | na    | na        | 0.000     | 5.000     | 45.000    | 48.000    | na
[2023-07-04 20:27:29.016] Mezz_Temp1       | na         | degrees C  | na    | na        | 0.000     | 5.000     | 80.000    | 85.000    | na
[2023-07-04 20:27:29.016] Mezz_Temp2       | na         | degrees C  | na    | na        | 0.000     | 5.000     | 54.000    | 57.000    | na
  • BMC may auto reboot to recover the sensor state:
EMS:
Fri Sep 05 14:58:08 +0900 [node01: env_mgr: monitor.shutdown.chassisOverTemp:EMERGENCY]: Chassis temperature is too hot: Multiple Internal Temp sensors are unreadable. System will be shutdown in 10 minutes
Fri Sep 05 14:58:24 +0900 [node01: env_mgr: monitor.shutdown.cancel:notice]: Automatic shutdown sequence canceled.
Fri Sep 05 14:58:24 +0900 [node01: env_mgr: sp.reboot.sensor.unreadable:notice]: Rebooting BMC because one or more sensors are unreadable.
Fri Sep 05 14:59:14 +0900 [node01: env_mgr: callhome.chassis.overtemp:EMERGENCY]: Call home for CHASSIS OVER TEMPERATURE SHUTDOWN
New to NetApp?
