NetApp Knowledge Base
"SHELF ID DELTA" warning reported for a DS2246 shelf
162
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS, AFF systems
  • DS2246 shelf
Issue
  • "SHELF ID DELTA" warning reported for a DS2246 shelf:
Enclosure Status: non-critical
Channel: 0a
Shelf: 10
Shelf Type: DS2246
Module Type: IOM6
Vendor Unique Element 83-IOM6: (SAS)
Element Status         Status Bytes  Status Descriptions
1 [IOM6 A]    : NONCRITICAL       03,09,00,20   SHELF ID DELTA, MASTER, RESERVED
2 [IOM6 B]    : NONCRITICAL       03,01,00,20   SHELF ID DELTA, RESERVED
The status of Temperature sensor 1 looks "OK"
Temperature Sensors:
  1: OK                01,00,2B,00
  • The issue reoccurred after manually changing the shelf ID and  physically power-cycling the shelf, following the steps as per Shelf ID Delta error reported
New to NetApp?
