NetApp Knowledge Base
E-Series replacement controller boots into OE LU state when expansion enclosure contain IOM12B modules
531
Visibility:
Votes:
0
Category:
e-series-santricity-os-controller-software
Specialty:
esg
Last Updated:
Applies to
  • NetApp E-Series
  • Controller Replacement
  • NetApp E-Series DE460C expansion shelf with IOM12B modules (Note the blue stripe vertically across the modules).
Issue
  • After performing a controller replacement, the replacement goes into lock down state with the display code being OE LU.
  • The controller console output or (excLogShow command) indicate the following assertion is hit by the controller:
ASSERT: Assertion failed: slotNum < numSlots, file ionLogicalUnit.cc, line 5240
New to NetApp?
