NetApp Knowledge Base
StorageGRID Low System Data Capacity - AutoSupport Message
771
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
NetApp StorageGRID
Event Summary
StorageGRID reports LowSystemDataCapacity indicating system data on the /var/local is low
Validate
  1. Login to the Primary Admin node
  2. Run df -h
  3. Verify space usage under /var/local
Resolution
  1. Verify if the space usage has already dropped below the threshold by running the df -h command
  2. Verify if the issue is related to one of below knowledge base articles:
  3. Verify if there is an old Lumberjack log, delete it if it is not needed
  4. Contact NetApp Technical Support if the available space continues to decrease and above articles are not applicable.
Additional Information
The /var/local space usage may increase temporarily when gathering log files
