NetApp Knowledge Base
StorageGRID Low Root Disk Capacity - AutoSupport Message
690
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
NetApp StorageGRID
Event Summary
StorageGRID reports Low Root Disk Capacity indicating the space available for root filesystem data is low.
Validate
  1. Login to the StorageGRID node with the reported low root disk capacity alert in Grid Manager using SSH.
  2. Run df -h
  3. Verify the usage under the / filesystem
Resolution
  1. Monitor this alert to see if the issue resolves on its own and the disk space becomes available again.
  2. Contact contact NetApp Technical Support if the available space continues to decrease or the alert does not clear
