NetApp Knowledge Base
SCE VSS_E_VOLUME_NOT_SUPPORTED_BY_PROVIDER errors
1,694
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter Plug-in for Exchange (SCE)
SnapCenter Plug-In for Exchange backups fail with the error VSS_E_VOLUME_NOT_SUPPORTED_BY_PROVIDER
Cause Resolution
Exchange database is stored on non-supported storage Migrate database to NetApp storage
Exchange host is unable to retrieve storage cache Check SSL configuration on SC server
Exchange host cannot communicate with the SVM Fix SVM name resolution or open Port 443 on the firewall
VSS System Writer has insufficient permissions Restart VSS Services
VSS writer SID has a .bak value in the host's registry Remove the .bak entries and reboot the host
Additional Information
Parent topic: Resolution guide for SCE backup failures
