NetApp Knowledge Base
SCE VSS_E_PROVIDER_VETO errors
2,470
Visibility:
Votes:
2
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter Plug-In for Exchange (SCE)
SnapCenter Plug-In for Exchange backups fail with the error VSS_E_PROVIDER_VETO
Cause Resolution
Insufficient free space in the volume to create a snapshot Increase free space on the volume
Space reservation is enabled on the LUN Disable space reservation
GPT Disk is missing a 'Reserved' Partition Create an MSR partition on the disk
GPT Disk is missing an 'Unknown' partition Extend the disk size
GPT Disk or partition on the disk has an issue Resolve the issue in the disk shown in the Application event logs
Duplicate SVM names or IP addresses Assign unique SVM names and IP addresses
Data ONTAP VSS Hardware Provider (Navssprv) password is incorrect Update the NAVSSPRV service account password
Data ONTAP VSS Hardware Provider (Navssprv) is corrupt or broken Repair the plug-in package and re-register the Navssprv service
SCE 6.2 backups failing when NAVSSPRV service returns an error, "GetTargetLunInfo FAILED", Upgrade SC/SCE to 6.2P1
Additional Information
Parent topic: Resolution guide for SCE backup failures
