NetApp Knowledge Base
Will NDE Scale work after changing default vMotion TCP IP stack
215
Visibility:
Votes:
0
Category:
netapp-hci
Specialty:
hci
Last Updated:
Applies to
  • NetApp Deployment Engine 1.8
Answer
You can modify default vMotion TCP/IP stack and NDE Scale will still let you expand existing HCI cluster
Additional Information
By using the vMotion TCP/IP stack, vSphere vMotion traffic can be assigned a default gateway on its own subnet and can go over layer 3 networks. The vMotion TCP/IP stack is not available in the default vDS vmkernel wizard, and therefore the vmkernel adapter must be created directly on the ESXi hosts.
Use this article to create the vMotion TCP/IP stack on the ESXi host
