NetApp Knowledge Base
Element cluster upgrade fails with: UpgradeError: Staging storage node <storage node name> failed on mNode
279
Visibility:
Votes:
0
Category:
element-software
Specialty:
hci
Last Updated:
Applies to
  • NetApp Element software
  • Management node (mNode)
Issue
  • On mNode CLI after running sfinstall  with --staging flag:
  • When exectuing the upgrade over the mnode-support-util script it stucks checking the upload speed
+ mNode ip: <ip>
+ MS version: 2.25.42
+ Authorative cluster: <ip>
+ mnode-support-util version: 3.5.1536B
Available clusters:
+ <cluster_name>
Enter the target cluster from the list: <cluster_name>
Healthcheck running...
Running check_var_log_disk_space on node Node <node_name> [1].
Running check_var_log_disk_space on node Node <node_name> [2].
Running check_var_log_disk_space on node Node <node_name> [4].
Running check_root_disk_space on node Node <node_name> [1].
Running check_root_disk_space on node Node <node_name> [2].
Running check_root_disk_space on node Node <node_name> [4].
Running check_upload_speed on node Node <node_name> [1].
  • When executing the upgrade over mNode HCC you might see an error:
Upgrade preparation failed due to critical error. ex=[UpgradeError: UpgradeError: Staging storage node xxx failed. Contact your technical support engineer.]
New to NetApp?
