NetApp Knowledge Base
What command can be used to monitor the storage efficiency progress on a FlexGroup volume?
473
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9.8
  • FlexGroup
Answer
Storage Efficiency job takes a long time to compete on large FlexGroup volumes, in order to have a granular way to check on the Storage Efficiency progress:
  • Check SIS-STATUS-L.XML in ASUP.
  • volume efficiency show -instance can only display the Storage Efficiency progress for the entire FlexGroup, it can't display the progress for the member volumes. There is a diag level command that could be used to display the progress on each individual volume.
    Please contact NetApp Technical Support or log into the NetApp Support Site to create a case. Reference this article for assistance with the solution.
    • The solution requires Diagnostic-level recovery.
    • The use of Diagnostic commands and recovery steps is potentially disruptive and should only be used with guidance from NetApp Support.
Additional Information
