NetApp Knowledge Base
AFF-A400 boot loop
1,486
Visibility:
Votes:
1
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • AFF-A400
  • Networking Adapter Cards NIC, 100GbE, PCIe gen3 x16,Smart IO with P/N X1151, Riser adapter
Issue
  • No BMC access.
  • Issue remains after a controller replacement
  • Boot loop console output example:
Wait BMC self-test result.
BMC self-test: OK.
UPI initialization.
CPU
initialization.
Running full memory initialization.
DIMM F0: NVDIMM with valid data and restage progressing.....
DIMM F0: NVDIMM
RESTAGE Success+++++++++
SPI FLASH: Backup BIOS
PEI end.
DXE start.
USB initialization.
PCI host bridge initialization.
CSM
initialization.
BIOS Version: 16.1
PEI start.
CPU PEI initialization.
Wait BMC 30 seconds.
BMC
self-test: OK.
UPI initialization.
CPU initialization.
CPU reset.
BIOS Version: 16.1
PEI
start.
BMC self-test: OK.
UPI initialization.
CPU initialization.
Running full
DIMM F0: NVDIMM RESTAGE Success+++++++++
SPI
FLASH: Primary BIOS
PEI end.
DXE start.
USB initialization.
CSM initialization.
  • BMC Access but will not system power on
  • this was a Faulty Riser Card
  • We see this output when the BIOS did not boot correctly
BMC >
BMC > system power status
Host power is off
BMC > system power status on
[876 : 942 INFO]CHASSIS_POWER_UP from channel 1
[876 : 959 INFO]CHASSIS_CTRL_ACTION: action: 1; SysRestartCause = 1
[876 : 959 INFO]POWER ON CHASSIS
[000101000646][IPMIMain][INFO]set bios to primary
BMC > system power onstatus
Host power is off
BMC > [000101000703][876:959:IPMIMain][ERROR][PDKHW.c:PDK_PowerOnChassis:321]Timeout to wait POWER_ON: retry=31
[000101000703][BIOS]PDK_PowerOnChassis change to ENABLE_WATCHDOG
[000101000703][IPMIMain][INFO]InitSysResetTick
BMC > [000101000722][BIOS]BIOSMonitorTask change from ENABLE_WATCHDOG to MONITOR
[000101000722][BIOS]Set WDT for 100 sec
[000101000722(946685242.816776216)][WDT]Set WDT req : Use=0x5 Action=0x3 Pre-timeout=0x0 Flag=0x20 Timeout=0x3e8
[000101000722(946685242.887375412)][WDT]Set WDT done: Use=0x5 Action=0x3 Pre-timeout=0x0 Flag=0x5 Timeout=0x3e8
[000101000722(946685242.888665920)][WDT]InitCountDown=1000
system power status
Host power is off
BMC > [000101000733][BIOS]Monitor: (count = 910, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=90
[000101000743][BIOS]Monitor: (count = 810, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=80
[000101000754][BIOS]Monitor: (count = 710, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=70
[000101000804][BIOS]Monitor: (count = 610, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=60
[000101000815][BIOS]Monitor: (count = 510, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=50
[000101000826][BIOS]Monitor: (count = 410, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=40
[000101000836][BIOS]Monitor: (count = 310, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=30
[000101000847][BIOS]Monitor: (count = 210, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=20
[000101000858][BIOS]Monitor: (count = 110, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=10
[000101000909][BIOS]Monitor: (count = 10, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=0
[000101000909][BIOS]BIOSMonitorTask change from MONITOR to CHANGE_BIOS because time out;
[000101000910][BIOS]BIOSMonitorTask change from CHANGE_BIOS to NONE_TIMER
[000101000910][BIOS]BIOSMonitorTask: Add SEL for OEM Timeout
[000101000910][BIOS]BIOSMonitorTask: ready to set up backup BIOS and power cycle
[876 : 950 INFO]POWER CYCLE CHASSIS
[876 : 950 INFO]Lock WDT
[000101000910][IPMIMain][INFO][easywdt_lock] Lock WDT
[000101000912][IPMIMain][INFO]set bios to backup
[000101000912][BIOS]PDK_PowerCycleChassis change to ENABLE_WATCHDOG
[000101000912][BIOS]BIOSMonitorTask: lock and stop watchdog
[000101000933][BIOS]BIOSMonitorTask change from ENABLE_WATCHDOG to MONITOR
[000101000933][BIOS]Set WDT for 100 sec
[000101000933(946685373.18518160)][WDT]Set WDT req : Use=0x5 Action=0x3 Pre-timeout=0x0 Flag=0x20 Timeout=0x3e8
[000101000933(946685373.87177168)][WDT]Set WDT done: Use=0x5 Action=0x3 Pre-timeout=0x0 Flag=0x5 Timeout=0x3e8
[000101000933][IPMIMain][INFO][easywdt_unlock] Unlock WDT
[000101000933(946685373.92590288)][WDT]InitCountDown=1000
[000101000944][BIOS]Monitor: (count = 910, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=90
[000101000955][BIOS]Monitor: (count = 810, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=80
[000101001006][BIOS]Monitor: (count = 710, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=70
[000101001016][BIOS]Monitor: (count = 610, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=60
Host power is off
BMC > [000101001027][BIOS]Monitor: (count = 510, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=50
[000101001038][BIOS]Monitor: (count = 410, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=40
[000101001048][BIOS]Monitor: (count = 310, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=30
[000101001059][BIOS]Monitor: (count = 210, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=20
[000101001110][BIOS]Monitor: (count = 110, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=10
[000101001121][BIOS]Monitor: (count = 10, TmrUse = 0x45, ExpirationFlag = 0x4), t_bios_load_time=0
[000101001121][BIOS]BIOSMonitorTask change from MONITOR to CHANGE_BIOS because time out;
[000101001122][BIOS]BIOSMonitorTask change from CHANGE_BIOS to NONE_TIMER
[000101001122][BIOS]BIOSMonitorTask: Add SEL for OEM Timeout
[000101001122][BIOS]BIOSMonitorTask: already using backup BIOS
New to NetApp?
