NetApp Knowledge Base
Unable to reset root Password on Brocade G610
2,240
Visibility:
Votes:
3
Category:
fc-series
Specialty:
san
Last Updated:
Applies to
Brocade G610
Issue
The procedure to reset the password is stuck at mounting the environment variables.
Example:
       scanning usb for storage devices... 1 Storage Device(s) found
*** badly formed bootargs in environment for GOS 0 ***
Hit ESC to stop autoboot:  0
1) Start system.
2) Recover password.
3) Enter command shell.
Option? 3
Boot PROM password has not been set.
=> setenv bootargs 'root=/dev/sda$prt rootfstype=ext4 console =ttys0, 9600 quite single'
=> saveenv
Saving Environment to NVRAM...
=> printenv
=> boot
=> mount -vo remount,rw,noatime /
Unknown command 'mount' - try 'help'
=> mount -vo remount,rw,notime /
New to NetApp?
