NetApp Knowledge Base
Brocade G610 or Brocade 300 switch does not power on due to Faulty PSU
1,466
Visibility:
Votes:
2
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
Applies to
  • Brocade G610 Switch
  • Brocade 300 Switch
Issue
  • Brocade switch suddenly turned off and does not power on, even after verifying a working power source and reseating the power cable.
  • No lights on the LED of the PSU.
  • The failed switch was not visible in the fabric.
  • Below steps need to be tried to isolate the issue further-
    • Check if power cords are tightly plugged in, on switch end and on power source.
    • Try connecting the power cord to a different power source.
    • Try powercycling the switch.
  • If issue persists, contact NetApp Technical Support and proceed to the solution.
New to NetApp?
