NetApp Knowledge Base
ifgrp shows broke while member ports are physically up with lag_inactive after DIMM replacement
625
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
core
Last Updated:
Applies to
ONTAP 9
Issue
  • After DIMM replacement with no cable reseated, ifgrp shows status broke, while member ports are lag_inactive in IFGRP-STATUS.txt:
a0b: 0 links, transmit 'IP Load balancing', Ifgrp Type 'lacp' fail 'default', Timer 'long'
Ifgrp Status Broke Addr_set
lag_inactive:
e2c: state lag_inactive, since 31Aug2021 18:48:14 (00:32:50)
mediatype: auto-10g_sr-fd-up
flags: lacp enabled
input packets 0, input bytes 0
input lacp packets 0, output lacp packets 621
output packets 618, output bytes 76632
drops (if) 0, drops (link) 0, drops (no active link) 0
up indications 2, broken indications 1
indication: lag_inactive at 31Aug2021 18:48:14
consecutive 0, transitions 3
e1c: state lag_inactive, since 31Aug2021 18:48:13 (00:32:51)
flags: lacp enabled
input lacp packets 0, output lacp packets 622
output packets 619, output bytes 76756
indication: lag_inactive at 31Aug2021 18:48:13
  • Member ports are physically up, show ports down in ifgrps.xml:
| node            | ifgrp-name | distr-func | lacp           | mac               | activeports | ports | up-ports | down-ports |
| node1netapp0102 | a0b        | ip         | multimode_lacp | xx:xx:xx:xx:xx:xx | none        | e1c   |          | e1c        |
|                 |            |            |                |                   |             | e2c   |          | e2c        |
New to NetApp?
