Why does node report ADP disabled while upgrading ONTAP or reboot
Applies to
- FAS
- AFF
- ONTAP 8.3.1 and later
Answer
- Advanced Disk Partitioning (ADP) is enabled by default on all FAS/AFF models running ONTAP 8.3.1 or higher.
- However, ONTAP disables the ADP feature when it is not needed. Possible scenarios include:
- Systems using unpartitioned disks for root aggregates.
- Systems using technologies such as Storage Pool, MCC-FC etc.
- On such systems, when the node gets reinitialized during the ONTAP upgrade, ADP is disabled again so that its original system configuration remains the same.
- This message will also be seen after a reboot of a node during the boot up process. A typical EMS message will look like:
Wed Mar 17 10:27:41 -0500 [node-03: sysinit_thread: callhome.raid.adp.disabled:alert]: Disk auto-partitioning is disabled on this system: ADP DISABLED.
Additional Information
N/A
