NetApp Knowledge Base
Why aggregate cross volume inline deduplication setting is changed
1,938
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9.4 or above versions.
Answer
Default Volume efficieny settings for destination RW volume on AFF setup upon snapmirror break(9.4 onwards):
  1. Volume efficiency state (enabled)
  2. Vol inline-compression(ON)
  3. Vol inline-dedupe(ON)
  4. Background compression (ON)
  5. Data compaction (ON)
  6. Cross volume inline dedupe (ON)
  7. Cross volume background dedupe (ON)
  8. Policy(auto)
FOR EXAMPLE:
The volume "vol3" is in Cross-volume-inline-dedupe false status, the host aggregate also in false.
Any of volumes in aggregate changes into Cross-volume-inline-dedupe true(ON) status, the host aggregate also changes into true(ON) status.
The sample volume "vol3" is configured snapmirror relationship, performs snapmirror restore for this relationship, the volume "vol3" gets break operation by snapmirror restore,  the volume Cross-volume-inline-dedupe gets to ture status, so the aggregate also changes into true status.
The existed status for the aggregate Cross Volume Inline Deduplication:
cluster1::*> snapmirror show
        Progress
Source            Destination Mirror  Relationship   Total             Last
Path        Type  Path        State   Status         Progress  Healthy Updated
svm1:vol3   XDP  svm1:vol3dp  Snapmirrored
                                      Idle           -         true    -
2 entries were displayed.
cluster1::*> volume efficiency show -fields cross-volume-inline-dedupe -volume vol3
vserver volume cross-volume-inline-dedupe
svm1    vol3   false
cluster1::*> aggr efficiency show -aggregate aggr2
                             Aggregate: aggr2
                                  Node: cluster1-02
Cross Volume Background Deduplication: true
     Cross Volume Inline Deduplication: false
Has Cross Volume Deduplication Savings: true
Has Auto Adaptive Compression Savings: true
cluster1::*>
Perform one snapmirror restore for vol3:
cluster1::*> snapmirror restore -destination-path svm1:vol3 -source-path svm1:vol3dp
Warning: All data newer than Snapshot copy
         snapmirror.aa1c00c8-2e93-11ed-8e6c-00a098d52e71_2161360053.2022-09-07_1
         50744 on volume svm1:vol3 will be deleted.
         Export policies currently enforced on the qtrees of volume "svm1:vol3"
         will not change during this operation. If the currently enforced
         export policies are different from those in Snapshot copy
         "snapmirror.aa1c00c8-2e93-11ed-8e6c-00a098d52e71_2161360053.2022-09-07_
         150744", reassign the export policies of the qtrees on this volume
         after this operation.
Do you want to continue? {y|n}: y
[Job 44] Job is queued: snapmirror restore from source "svm1:vol3dp".
        Progress
                                      Idle           -         true    -
svm1:vol3dp RST  svm1:vol3    Broken-off
                                      Queued         -         true    -
3 entries were displayed.
        Progress
                                      Idle           -         true    -
svm1:vol3dp RST  svm1:vol3    Snapmirrored
                                      Idle           -         true    -
        Progress
                                      Idle           -         true    -
svm1    vol3   true
                             Aggregate: aggr2
                                  Node: cluster1-02
     Cross Volume Inline Deduplication: true
cluster1::*> event log show
Time                Node             Severity      Event
9/7/2022 15:10:29   cluster1-02 NOTICE        sm.break.enable.se: "Storage efficiency" feature has been enabled on the destination volume svm1:vol3 due to a SnapMirror break operation.
9/7/2022 15:10:09   cluster1-02 INFORMATIONAL wafl.scan.ownblocks.done: Completed block ownership calculation on volume vol3@vserver:aa1c00c8-2e93-11ed-8e6c-00a098d52e71. The scanner took 1 ms.
9/7/2022 15:10:09   cluster1-02 INFORMATIONAL wafl.vol.blks_used.done: type="Volume", owner="", vol="vol3", app="", volident="@vserver:aa1c00c8-2e93-11ed-8e6c-00a098d52e71", run_time="110"
9/7/2022 15:10:09   cluster1-02 INFORMATIONAL wafl.vol.snap_create.done: type="Volume", owner="", vol="vol3", app="", volident="@vserver:aa1c00c8-2e93-11ed-8e6c-00a098d52e71", run_time="42"
9/7/2022 15:10:09   cluster1-02 DEBUG         wafl.scan.start: Starting redirect on volume vol3@vserver:aa1c00c8-2e93-11ed-8e6c-00a098d52e71.
9/7/2022 15:10:09   cluster1-02 INFORMATIONAL wafl.snaprestore.revert: Reverting volume vol3@vserver:aa1c00c8-2e93-11ed-8e6c-00a098d52e71 to a previous Snapshot copy with snapid 2.
