NetApp Knowledge Base
Takeover disabled due to interconnect down
6,078
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF/FAS Models
  • HA Interconnect
Issue
  • Alert received that takeover is unable to be performed due to interconnect link being down
[Node-01: cf_main: cf.fsm.takeoverOfPartnerDisabled:error]: Failover monitor: takeover of Node-01 disabled (HA interconnect error. Verify that the partner node is running and that the HA interconnect cabling is correct, if applicable. For further assistance, contact technical support).
  • Interconnect port link flaps or goes down
[Node1: gop_eq: ic.linkStatusChange:info]: HA interconnect: Port ic0a link is down.
[Node1: gop_eq: ic.linkStatusChange:info]: HA interconnect: Port ic0a link is up.
  • Storage failover shows 'takeover possible' as 'false'
Cluster::> storage failover show
                              Takeover
Node           Partner        Possible State Description
Node-01         Node2-02        false  Waiting for Node-02, Takeover
                                       is not possible: Storage failover
                                       interconnect error, NVRAM log not
                                       synchronized
Node-02         Node-01         false  Waiting for Node-01, Takeover
                  synchronized
New to NetApp?
