NetApp Knowledge Base
Health Monitor reports a switch is down: SwitchIfIslDownWarn_Alert
551
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
HW
Last Updated:
4/1/2022, 9:45:48 AM
Applies to
Cisco 3132Q-V Cluster Network Switch
Issue
  • Switch-02 (cluster switch) is not working. All traffic is served on Switch-01
  • A Health Monitor alert is sent out via AutoSupport
Mar 17, 2022 08:29:08 CET HA Group Notification (Health Monitor process cshm: SwitchIfIslDownWarn_Alert[Switch-02 (xxxx)/Ethernet1/31]) ALERT
  • In the EMS-LOG-FILE section of the AutoSupport:
Tue Mar 15 16:25:13 CET [Node-05: cshmd: hm.alert.raised:alert]: Alert Id = SwitchIfIslDownWarn_Alert ,
Alerting Resource = Switch-02(xxxx)/port-channel1 raised by monitor cluster-switch
  • The switch log (# show tech-support
2022 Mar 15 16:21:07 Switch-02 %DIAG_PORT_LB-2-REWRITE_ENGINE_LOOPBACK_TEST_FAIL: Module:1
Test:RewriteEngine Loopback failed 10 consecutive times.
Faulty module:  Error:Loopback test failed. Packets lost on the SUP in the receive direction
2022 Mar 15 16:21:07 Switch-02 %DIAGCLIENT-2-EEM_ACTION_HM_SHUTDOWN: Test <RewriteEngineLoopback>
has been disabled as a part of default EEM action
2022 Mar 15 16:21:07 Switch-02 %MODULE-4-MOD_WARNING: Module 1 (Serial number: xxxxx) reported warning due to Loopback test failed.
Packets lost on the SUP in the receive direction in device DEV_SUPERVISOR_CTRL (device error 0x41830059)
2022 Mar 15 16:21:07 Switch-02 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin on vsh.bin.4635
  • Switch commmand # show module
Switch-02# show module
Mod  Ports             Module-Type        Model                 Status
1    32                32x40G Supervisor  N3K-C3132Q-V          active *
Mod  Sw                Hw     Slot
1    7.0(3)I6(1)       1.0    NA
Mod  MAC-Address(es)                         Serial-Num
1    d4-xx-xx-xx-xx-xx to d4-xx-xx-xx-xx-xx  xxxx
Mod  Online Diag Status
1     Fail
New to NetApp?
