NetApp Knowledge Base
PSU reports DC FAIL, AC FAIL, OFF
4,226
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
  • AFF and FAS systems
  • ONTAP 9
  • Power supply unit (PSU)
Issue
  • EMS reports the following error message.
[Node-A: statd: monitor.shelf.fault:alert]: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
[Node-A: statd: callhome.shlf.fault:error]: Call home for SHELF_FAULT
[Node-A: dsa_worker4: ses.status.psError:alert]: DS212-12 (S/N SHFNCXXXXXXXXXX) shelf 0 on channel 0b power error for Power supply 2: critical status; AC Fail. This module is on the rear of the shelf at the bottom right.
[Node-A: dsa_worker4: callhome.shlf.power.intr:error]: Call home for SHELF POWER INTERRUPTED
Or
[Node-A: dsa_worker2: ses.status.psWarning:error]: DS212-12 (S/N XXXXXXXXXXXXXXX) shelf 2 on channel 0a power warning for Power supply 2: warning status; DC undervoltage. This module is on the rear of the shelf at the bottom right.
[Node-A: dsa_worker2: callhome.shlf.ps.fault:error]: Call home for SHELF POWER SUPPLY WARNING
  • storage show fault shows PSU is CRITICAL.
Power Supplies:
Element Status         Status Bytes  Status Descriptions
  1: CRITICAL          02,00,00,F1   DC FAIL, OFF, RQSTED ON, FAIL
  2: OK                01,00,00,20   RQSTED ON
OR
  1: CRITICAL          02,00,00,F3   DC FAIL, AC FAIL, OFF, RQSTED ON, FAIL
Fans:
  1: CRITICAL          02,00,00,F0   OFF, FAIL
  2: CRITICAL          02,00,00,F0   OFF, FAIL
  3: OK                01,01,2C,21
  4: OK                01,01,29,21
Enclosure:
  1: OK                01,00,02,00   FAIL
Voltage Sensors:
  1: UNRECOVERABLE     04,00,00,00
  2: UNRECOVERABLE     04,00,00,00
  3: OK                01,00,01,FB
  4: OK                01,00,04,C6
  • The affected PSU lights amber LED.
  • ENVIRONMENT reports voltage sensor error:
Voltage Sensor installed element list: 1, 2, 3, 4; with error: 1, 2
Shelf voltages by element:
[1] <N/A> sensor condition <N/A>
[2] <N/A> sensor condition <N/A>
[3] 5.00 Volts  Normal voltage range
[4] 12.02 Volts  Normal voltage range
New to NetApp?
