Portset create failed with the error "No nodes are available to process the command. Verify that all nodes are healthy using the "cluster show" command, then try the command again"
Applies to
- ONTAP 8
- ONTAP 9
- SAN
- iSCSI
Issue
Unable to create portset:
xxx-xxxxxxx::> portset add -vserver SVM_XXX -portset Portset-X -port-name iSCSI-LIFX
Error: command failed: No nodes are available to process the command. Verify that all nodes are healthy using the "cluster show" command, then try the command again.
