NetApp Knowledge Base
WARNING: there do not appear to be any disks attached to the system Resolution Guide
3,856
Visibility:
Votes:
5
Category:
disk-drives
Specialty:
hw
Last Updated:
Applies to
  • AFF Systems
  • FAS Systems
  • ONTAP 9
  • Storage
While attempting to boot an AFF or FAS system the following messages might appear:
WARNING: 0 disks found!
Storage Adapters found:
2 Fibre Channel Storage Adapters found!
4 SAS Adapters found!
0 Parallel SCSI Storage Adapters found!
0 ATA Adapters found!
Select option 4 from the boot menu to choose disks for the root volume and spare core space.
Target Adapters found:
2 Fibre Channel Target Adapters found!
0 iSCSI Target Adapters found!
WARNING: there do not appear to be any disks attached to the system.
No root volume found.
Rebooting... (press ctrl-c during boot to break reboot loop)
New to NetApp?
