NetApp Knowledge Base
How can I create a temporary account for a field engineer to login to perform maintenance work on a cluster
942
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • FAS Models
  • AFF Models
  • Ontap 9
Answer
In some cases, it might make things more streamlined to provide a unique account for a field engineer to work on your cluster, rather than sharing "admin" credentials.
To perform these actions, SSH to the cluster and run the following commands:
1)  Create the user named "field_tech"
::> security login create -user-or-group-name field_tech  -application console -authentication-method password -role admin
You will be prompted to enter a password
Please enter a password for user 'field_tech':
Please enter it again:
2)  Add access to the "service-processor" application
::> security login create -user-or-group-name field_tech  -application service-processor  -authentication-method password -role admin
3)  Verify that the account has been created properly
::> security login show -user-or-group-name field_tech
Vserver: tfmb
        Second
User/Group                 Authentication                 Acct   Authentication
Name           Application Method        Role Name        Locked Method
field_tech     console     password      admin            no     none
field_tech     service-processor
2 entries were displayed.
Once the maintenance work has been completed, you can "lock" the account so that it can't be used
::> security login lock -username field_tech
Future maintenance windows can have the account unlocked with this command
::> security login unlock -username field_tech
and the password can be changed at anytime with this command:
::>  security login password -username field_tech
Additional Information
security login commands
