NetApp Knowledge Base
FAS8700/FAS8300/AFF A400/AFF C400 reports (CHASSIS OVER TEMPERATURE) ERROR warnings
3,089
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9
  • AFF A400, AFF C400, ASA A400, ASA C400
  • FAS8300
  • FAS8700
Issue
  • Hourly error messages for chassis temperature, in both nodes. Example:
[node_name-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (LED1 Temp) is not readable.
[node_name-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (LED2 Temp) is not readable.
[node_name-01: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
[node_name-02: env_mgr: monitor.temp.unreadable:error]: The controller temperature (LED1 Temp) is not readable.
[node_name-02: env_mgr: monitor.temp.unreadable:error]: The controller temperature (LED2 Temp) is not readable.
[node_name-02: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
  • AutoSupport generated with:
HA Group Notification (CHASSIS OVER TEMPERATURE) ERROR
  • LED1 or LED2 Temp sensor failed. Example:
::> system node run -node node_name-01 -command environment chassis list-sensors
Sensor Name    State             Current    Critical     Warning     Warning    Critical
                                 Reading      Low         Low         High       High
LED1 Temp      failed             -- C      0 C          3 C         43 C       46 C
OR
::> system node run -node node_name-01 -command environment status chassis
LED1 Temp                not_available     -- C         0 C         3 C        43 C        46 C
LED2 Temp                not_available     -- C         0 C         3 C        43 C        46 C
  • "No reading" outputs for the LED sensors in the BMC debug logs. Example:
LED1_Temp        | 16h        | ns         | 12.1  | No Reading
LED2_Temp        | 17h        | ns         | 12.1  | No Reading
LED1_Temp        | na         | degrees C  | na    | na        | 0.000     | 3.000     | 43.000    | 46.000    | na
LED2_Temp        | na         | degrees C  | na    | na        | 0.000     | 3.000     | 43.000    | 46.000    | na
  • In certain scenario, node may Panic as well with below messages:
[node_name-02: env_mgr: monitor.shutdown.chassisUnderTemp:error]: Chassis temperature is too cold: Ambient temperature is critical low. System will be shutdown immediately
[node_name-02: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too low..
[node_name-02: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Temperature critical)
[node_name-02: mgwd: mgwd.notify.halt.result:info]: MGWD able to notify CLAM on its HA partner node that this node is undergoing a planned shutdown (reason: E). Error: -
New to NetApp?
